Blown Inline Fuse?
kpilai123
One day, I decided to crank up my stereo loud, I have an aftermarket deck, but still the regular wiring (1993 saturn), and when I hit a certain volume my deck died. Display, cd eject, nothing powered on. I checked the fuse in the rear of the deck, not blow, the radio fuse by the dashboard, and it wasn't blown either, so I'm now thinking it was an inline fuse, after that, I'm out of options and I kind of want to cry lol. So, if it is an inline fuse blown, how would I know it's blown, how would I replace it, and if it's not the inline fuse, what could it possibly be, and what could be another solution. I thought of wiring the ground and the power/ignition right to the battery, but I don't know what that would do.
You can check if a fuse is blown by taking it out and measuring it with a multimeter set to the continuity function. If the fuse is still good, the meter will produce a sound when you touch the leads to the fuse.
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
5K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
kpilai123
kpilai123
Honolulu
Kangaroux
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
