blown mid on infinity components
They probally will "work" but who knows how well. Components are designed as a set. The crossovers are usually designed for a specific set of speakers to be attached to it. The Inifinity speakers may have a slightly difffernt reactance than the Kicker ones and as thus the crossover point may be changed. This could cause the Kicker speakers to attempt to play frequencies they were not designed to do. There is also a sensitivity difference probally and the mids won't sound "matched" to the tweeters. From what I understand it would be best to try and get the exact model of mids you had before.
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
5K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
LowLinc
LowLinc
Oxnard CA
LowLinc
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
