Box expert needed
cyantist
freqshow
I'm designing a dual slot-ported box for my single 15" Brahma and was wondering if somebody experienced could run the numbers, so to speak, and confirm these dimensions. The box will be built using 1" MDF, and the inner walls of the slot ports will be made using 3/4" MDF. The measurements I have are:
Outer Dimensions - 30"W x 17"H x 22"D
Port Dimensions - 10"W x 2.5"H x 26"L (x 2)
The main concern I have is that I may not have done the math correctly by calculating the slots as solid objects. Are they?? If they are not calculated as solid objects, then what is the proper formula to use? The formula I used was 10.75 x 3.25 x 52 = 1.05^ft, which I added to the original 3.5^ft along with the 0.24^ft displacement of the driver, +-0.10^ft for some bracing material, which gives a gross volume of 4.9^ft.
If my calculations are correct, this gives me approx. 3.5^ft net volume tuned to 26Hz (not to mention some nice bump in the trunk).
Sorry to be a PITA, but I really want to get this right the first time as this box is going to be permanently mounted in the vehicle and changes won't be easy to make once it's in place. Does everything look correct? I just want to get some confirmation by a pro before I start construction later this week.
Thanks in advance...
I get a total box volume of 4.86cu'
Your ports will measure a total of 50" in length. You forgot to subtract the 1" for the face of the box. This will give you 1.01cu' of port displacement.
4.86 - 1.01 - .24 = 3.61cu'
A box with a vol. of 4.4cu', using two ports tuned to 26Hz, the ports would have to be 51" long each. So I guess that this would be out of the question.
Is there any special reason that you want to have two ports??
Try this:
Keep the box dimension that you have. (I have almost the same thing but I used 3/4".) Put the port on one side. I will be 15" tall x 3" wide x 22" long. This will give you 45sq" of port and tune it to ~30Hz.
1.3cuft isn't enough airspace. Shredders box plans are simple enough if you want to save a couple bucks.
10
174
FEATURED Sniper Box
6th order series bandpass tuned to the vehicle resonant frequency. Basically a one hit wonder box.
266
https://www.ebay.com/p/3025988078?iid=302622841801 This was for a 15" but i liked it until i toasted the sub.
11
655
Have you checked out these shallow drivers from DD? A friend had 4 of them and man, it took it to the house for what they are...
6
567
My guess is, once you get the speaker in it, more like 34hz so good to go. With that unit, try it up, try it to the rear, see which works best...
12
771
cyantist
freqshow
cyantist
British Columbia
Trixter
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
