Box question
might be really big if you do it that way and you may actually take up more space than you want. Consider doing something that utilizes the space a little better if its possible.
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Yeah I'm in a circle right now too. I'm going to use 3/4" birch so I don't want to build it twice, stuff ain't cheap.
5
Emphasis added. The answer is, because you can also see DCR at other frequencies and because low impedance is extremely torturous on...
9
Common chambered sealed or ported is fine. Just make sure you have sufficient bracing
1.3cuft isn't enough airspace. Shredders box plans are simple enough if you want to save a couple bucks.
10
174
ckarls2000
ckarls2000
Everett, WA
ted_the_mexican
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
