Box Question
  • 3
Billyf17
I just purchased 2 Audiobahn AW1251Q. I want to make a box for it. I have a question about volume.
I want both subs in one box. In the book that came with the subs, the max. sealed volume in the book says 1.66 cu. ft. Since I am putting both in the same, would 1.84 cu. ft. be fine? Since it's past max for one I thought making a little bigger would be perfect for both. Gimme input.
no needs to be 1.66 for each, that would mean you will need a box that is 3.32 cubic foot , and if it were me I would put a divider in it.
yes, i had some audiobahns and i built the box without a divider to see what it would sound like and just to my surprize it saounded like poopy. lol well i figuered it would sound like poop but ya know. but i put the divider in and then it sounded good. **** good for the money
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Yeah I'm in a circle right now too. I'm going to use 3/4" birch so I don't want to build it twice, stuff ain't cheap.
5
Emphasis added. The answer is, because you can also see DCR at other frequencies and because low impedance is extremely torturous on...
9
Common chambered sealed or ported is fine. Just make sure you have sufficient bracing
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
Billyf17
Billyf17
Lehighton, PA
EVOECLIPSE
BassErex
    Jul 3, 2024
BassErex
    Jul 3, 2024
