Bridging 4ch Amp
sdime808
7
HI
I thought I read another thread about this but I can't find it, sorry if its a repost!
I want to bridge my 4 ch amp for my boston components up front. But from what I understand bridging makes the ch mono. How can I bridge the amp while keeping it in stereo? Is this possible?
i dont have experience with bridging, but if your trying to bridge all 4 channels together then it will be mono. if your briding channel 1 & 2 toghether, in additon to channel 3 & 4 as a seperate channel then you will have two channels, so it could be stereo then.
this is just what i think, i dont have experience, so i could be completely wrong.
some amps have switch for 2 or 4 channel. you will just use one set of inputs and both sets of speaker outputs in bridged mode.
it's easy.
Connect a pair of y cables to the front outputs from your HU.
Connect both L's to ch 1/2, and both R's to channel 3/4. Or vice versa.
Bridge it.
That's all there is to it.
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
Did you integrate the C60 between the OEM radio and OEM amp?
sdime808
sdime808
HI
sdime808
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
