Can anyone Help me with a slotted port box?
My max height is 15.5". I know it going to be a pain. Depth is max of 44" and max width is 34. Are you using a box design program. If you are could you take the time and tell me how to use it sometime cause. I would like to learn. Just get a rough idea what it will be. Because i am going to finish my trunk this weekend. I am lining it with 3/4 mdf and the specs might change to be bigger or smaller.
Here are the specs.
2600 watts power handling
1500 Watts RMS
340 oz. magnet
4” BASV/Kapton Hybrid 18 AWG Voice Coil
SPL 92 dB
Fs: 33.5 Hz
Vas: 1.4 cu.ft.
Qms: 7.17
Qes: 0.51
Qts: 0.4795
Xmax: 0.9"
Sealed box: N/A
Ported box: 3.4 cu..Ft.
Tuning: 40 Hz
Port size: 4”(dia)x8.25”(length)
# of ports: 2
Non-pressed paper cone with aluminum rib insert (patent pending)
Dual 2ohm voice coil
Die cast aluminum
Metal-flake Royal Blue Finish With Diamond Cut
Chrome Finish Front & Back Plate
Large foam rubber surround
1-piece Rubber Gasket
Dual Conex Spider
Woven Tinsel Lead Through Spider
Chrome Screw Terminals
ok, i'll try to run some number sometime soon. Got a state tournament basketball game 2night...i'll be using WINisd box program...and yes the height will be a pain in the ass. But yeah, hit me up on AIM sumtime...sn is in the sig. peace
NG
Ok, so...here's what i got
width: 30.5"
Depth:30.5"
height: 14"
those are all internal dimensions.
Port: 12"x4" length of 10"
this will tune it to 33.8hz to be exact...and after all displacement (port displacement and driver displacement) will be 7 cubes @33.8hz. Should work great, peace
NG
Okay got max dimensions. 15in tall, 30.75in wide and up to 36 deep. If you could sketch a desigh for a slotted port box with those specs that would be awesome. i know there is angling to be done. Will the subs be as loud since they are probably not going to be directly facing the back.
https://www.addictiveaudioinc.com/pure-amplifiers
https://www.americanbassusa.com/products/titanium-8-slim-subwoofer Since I've put off my delta 88 build til January or February cause our new...
I'm looking at replacing my 10" Kicker CompR. I have a Kicker 46CXA400.1T that does 400x1@1 ohm and a Fox Acoustics sealed box for a 2016 Ram 1500...
Do you know how much mounting depth you have? Is it a crew cab?
4
538
There is a amp dyno video by big d on youtube of one of these amps.
monte_carlo97
Power Acoustik Punk
monte_carlo97
Central Ohio
monte_carlo97
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
