Charging headway bank.
  • 2
Erick Thomason
CarAudio.com Newbie
Tn
99 f150.
300 amp alternator 14.6
Superbeast conversion to 12 v
Ioxus ultracapacitor 12v.
3000 w stetsom is biggest amP so far but I'm looking for another one. I don't have my lithium battery Or ultracapacitor installed bc I don't want to Burn my truck uP. If I can't put it all together then I at least want my Lithium to work. Do I need a special bms t charge /discharge fast?h Ow should I charge It
With the HO Alt on a 4-5000 watt system, get a 2ND battery, especially at the price of the Loxus, a Glow Voltage series 1 or 2 would be a far better choice - and they're in stock. $499
- OR -
- OR -
Nothing special needed.
Parallel 1/0 or 2/0 +/- gauge cables to the 2nd battery. Fused distro blocks for +/-, parallel ground, good to go.
https://www.bestcaraudio.com/car-audio-myths-you-cant-ground-a-car-audio-amplifier-to-the-battery/
If you want to be able to disinguage the 2nd battery, use an isolator like this which allows you to turn off access to the primary battery from the system end.
14.6 is max charge for headway. 3.65 volts per cell. There should not be any voltage drop from your alternator wiring to battery so 14.8 is too high.
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
3K
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
How often are you charging? I charged mine once when I built it over a year ago and maybe a couple times while I had the car pulled apart. I...
For the pt cruiser, neons, and other pcm controlled charging systems these parameters need to be altered with tuning software. The two tuners I...
6
Erick Thomason
CarAudio.com Newbie
Erick Thomason
Tn
Doxquzme
spokey9
    Jun 29, 2024
1aespinoza
    Jun 29, 2024
