Cheap Subs!!!
brs954
Need MORE power!!!!!
91
NY
OK...
I think that I am having some second thoughts on if I should by 2 MA Audio MA120xe's. I really think that I might be able to find some other subs that are better than these for the same price.
BUT...
I need to have your help to try and find these.
//content.invisioncic.com/y282845/emoticons/help.gif.cee8f684da1ba626487a8bc51152e1ec.gif
Well in your sig you said you got both of them for 140, which is relatively cheap. I've only heard the higher end MA subs, and was not even slightly impressed with their sq. The subs that come to mind near that price range are the ED Kx's. Those subs are commonly compared to the Infinity Perfects, but usually win the comparison. I think phoenix gold has a cheap sub around the same price range, i'm sure there will be some good recomendations on here, but im still with the ED Kx.
Thats what i meant acura......i thought everyone would know thats what i meant as i dont even consider the reg comps as subwoofers considering they r like 80 bucks a pair on ebay.But thanks for the repost as i did leave the vr out.
IMO There are better for the money than the Vr's. I was not impressed whatsoever with their sq. They did get somewhat loud, but most subs can. Get K's, or Kx's, Hell try out a B212 or two.
Starting from scratch don't have an amp yet gonna wait till I make a decision on which subs right now I'm just trying to settle on which subs I'm...
5
My first install on my vehicle was in '94 right before I turned 18 😂 I'd "helped" on a few starting at 16 but my helping was mainly gofer work...
19
3K
I have not really heard anything bad about Vibe Audio. If you are buying it new, then no reason to not try it out. It may have a 3 month...
These are custom built using triple stacked y35 motors with cross drilled back plates and vented pole pieces which are also radially drilled for...
brs954
brs954
NY
nosaj070
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
