Comps wont fit in stock baffles
  • 3
is the back of the magnet touching the speaker basket ? depending on how deep your mid drivers are. With the door panel off. take off the actual speaker basket and you can cut the plastic backing on it. it will give you a bit more depth to work with ? its a common issue with honda/acura owners.
i had to do that with mine till i made some 3/4 mdf spacers. night and day difference between the stock flimsy plastic and the mdf spacers
I have tons of MDF and a circular saw. But I dont have anything to cut the inside of the ring. any cheap tool under $10 that u guys know that I can use to cut the inside of the ring? I think I'm gonna bust out with some ghetto ass baffle.
You can get a jigsaw for ~$25, use it once and then return it.
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
4K
Im really glad I found this site, you've all taken time to help me out, much appreciated!!! I got a ported kicker brand box and 2 of those 12 sub...
9
The install looks very nice and clean for sure. Thanks for sharing the pics as well as your experiences
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
duckfart
duckfart
Long Beach, CA
duckfart
edweather
    Jun 27, 2024
edweather
    Jun 27, 2024
