computer power supply?
No, the computer power supply can't even power a hu properly (tried before). If I'm not mistaken, the pwoer supply makes about 3~5A ont he 12V, i think.
If you want to power car audio products at home, then get yourself a dedicated power supply, no two ways around it, if you ask me. Even battery chargers are supposed to emit noise into the system.
That is most likely a cheaper power supply, i have never even heard of or seen that brand. Anything like an Antec, TTGI, PC Power and Cooling, Enermax, or Thermaltake will put out a good amount more power.
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
Certainly depends on the vehicle and type of enclosure tuning for the subs and direction of the subs and port to begin with, then power...
7
191
If you are using an aftermarket headunit, make sure your subwoofer is set to 'on' in the settings menu
4
233
https://www.amazon.com/dp/B0B3X3C7RD/?tag=caraudiocom-20 This is one of the better reviewed budget touchscreens. I just about pulled the trigger...
558
missionpilot
missionpilot
Gulfport, MS
paikiah
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
