copper vs. aluminum voice coils
Copper has better conductivity, meaning you can get a higher current density for a given gap topology (read: higher BL and a lower Qes). Aluminum is lighter, so you have a higher resonant frequency.
Bottom line - it really doesn't matter to the consumer. If a driver company pushes one over the other, it's usually because they don't have anything worthwhile to talk about...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Dan Wiggins
Adire Audio
I see the heat has melted your brain...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I told you I wanted them made of unobtainium!
Dan Wiggins
Adire Audio
- with more years of just physics and chemistry than you've been alive -
Dan = teh old..
and I'll post a pic to prove it ! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
-you know what pic it is too //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif -
Loyd L.
Loyd, you stop that... You're brain's been fried from being next to those speaker magnets on your head...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Dan Wiggins
Adire Audio
- I may be old, but I can still make things that bump -
Works Hey Brain My Now Fine!!!!!!!!!!!!!!
L Loyd
Dan Wiggins
Adire Audio
I tested a XXX vs. a Brahma and the XXX won so the aluminum coil is better and thats what made all the difference so shut up meanie man!
:blow_up:
Zinc also conducts fairly well. I use zinc nuts and bolts on the terminal cups I build into my boxes.
5
Link to antenna. I'm guessing the copper foil should be connected to glass, not metal, but lets see the antenna. Did it come with instructions?
I would face the port and sub back. Even if you got a soft top, the rear gate will serve as a loading wall. I looked at the specs for the 10w6v3...
421poolman421
421poolman421
seattle
TeamPSI
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
