couple ohm questions
  • 3
also when you get into more then 2 coils, you get series parallel as a option, its simple math though, just take the time to figure it out if your looking at that many subs.
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
6
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
6
The SIA is a great line of amps. People like to hate. My little SIA does work with 4-8's. And it bangs the lows.
23
7K
It also lowers the amps efficiency and raises the current draw.
5
822
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
631
solidcrowd
solidcrowd
Buffalo, New York
DarkFox
edweather
    Jun 27, 2024
edweather
    Jun 27, 2024
