Crossovers
neil4374
When I started this first car audio installation I didnt think it would be so easy for me. I am not so good at thinks like this. However the challenge seemed a good idea. After buying all my equipment, asking questions and getting help I am enjoying it all the more. But I keep getting more and more questions.
Can somebody please tell me if I am on the right lines...!
Regarding crossovers...
1.Passive crossovers are included in component speaker sets.They go between the amp and the speakers
2.Active crossovers are between the headunit and the amp?
I can see crossovers on my amp(1 high and low for each channel)
3.Are they classed as Active?
4.And is it also the case that I shouldnt use croosovers on the amp and on the speakers at the same time?
Cheers
#1 . Yup
#2 . Also yup
#3 Again, yup
#4 ....sorta. When someone states going active with their setup, the x-overs on the amp(s) get left alone and using the HU's active x-over built in.
@Jeffdacheff has more knowledge in that area. He can prob give ya more in depth info better than I can.
Thank you for clarifying I was right:)
I am quite surprised I got it right.
My crossovers on my components speakers have no settings to change. Only db+ and db-.
Am I right in saying these normally come prefigured?
That's correct. In fact, I don't think any x-overs that come with comp sets are adjustable. I wanna say I've seen one or two in the past but nah. That would be either the HU or amp(s).
that will be $40 my btc wallet is 5748384758585854445... jk! :ROFLMAO:
8
So I did a tone test and found that the tweeters start making sound at about 1500hz which would put the crossover several thousand hertz above...
4
877
neil4374
neil4374
los angles
Boomin_tahoe
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
