Current Draw
  • 3
How many amps will 2kwatts draw? 3k?
It depends on the efficiency of the amp at the impedence you're wired to and the frequencies are being played through it.
How many amps will 234ah of battery and a stock alt (dunno size..'04 ram 1500 work truck) be able to sustain?
Sustain? Batteries do not help the system "sustain" current draw. Only an alternator can help the system sustain. Batteries merely prolong failure. It has reserve current at 12v and once it is depleted, the battery is no longer useful, and the amp will either shut off or blow from clipping like crazy. So the question you're really asking is, based on my duty cycle will my equipment last if I put a 3000 watt amp on stock electrical? The answer is no, and your amp will not put out anywhere near what it is rated at either. Do it right the first time or you will pay later.
I'll agree. A large stock alt with upgraded batts you might get away with 2kw, but you'll probably want to upgrade your alt if you go higher than 2kw.
Ill have 2k and 2.5k at most. Wired at 1 ohm. Lets say a pretty efficient amp..comparable to a saz-2k. Big 3, 2 big batteries, 2 power/grounds, and stock alt isn't enough for 2k?
I have nearly the same setup. I dip to around 13.0v min at a stop light. Dimming is barely noticeable.
I was just saying that if you go with any more power then you'll probably have some issues.
Class A/B, right? If I recall, these little 2x30 watt jems could best several hundred watts, mono. One of RF's endearing qualities on most of...
5
Yeah i Yeah I know. I have my sub wired at 4ohm so I can get 300w rms from old amp. It’s 1000w max. And yes that’s the reason I got this pioneer...
40
4K
I like the MA Audio HK series ..ive ran and won with them at car audio comps
5
If you have not already done this, do a thorough job of sound deadening the doors before spending a lot of money new equipment. This is probably...
4
Disconnect the battery lead at the alternator and see if your power still drains. Or, disconnect everything from the battery so just the battery...
Bobby322
Bobby322
TX
Bobby322
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
