dc 175.4, which speakers
Here are my options:
Front: CDT Audio- MX 369- 3 way component- (suggested by trumpet)
Rear: Sundown Neo Pro 6.5s
or
Front Sundown Neo Pro 6.5s + Vifa or Crescendo Tweeters
Rear Sundown Neo Pro 6.5s
or
Front: PWX 6.5s + FT-1 or Vifa Tweeters
Rear: PWX 6.5s
Which would you choose to pair with my 2 Sundown x-12s to have a clear sounding front stage???
Cdt mc 369 set. I'm running an Es version and mine are loud and very clear. I'm also running a vfl 350.4 all channels bridged for the components only so I'm seeing about 300+ rms per side
That sounds like an idea that I am considering. However, I have no idea for the rear stage. I could really do the neos in the back and be done. Basically, I need something(6.5s) that will be okay with 175rms watts.
Ditch the rear speakers. I mean, it's personal preference of course, but most people much prefer the sound of fronts only once they get used to a properly done front stage.
There will definitely be a mechanical noise when you overpower the speakers. That sound will show up long before overheating the coils. Like most...
BNIB - XSP65KIT 600W Peak (200W RMS) 6.5" X-Series 2-Way Component Speakers with Carbon Fiber Cones and 25mm Silk Dome Tweeters
BNIB XSP652 600W Peak (200W) RMS 6.5" X-Series 2-Way Coaxial Speakers with Carbon Fiber Cones and 25mm Silk Dome Tweeters
You tap into the 3.5s and the 6x9s then use the summing feature. This will sum the 3.5 and 6x9 frequencies into a full range output.
610
bluephigomab
Ashburn,VA
gckless
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
