Gearstix
Okay, well the worst case scenario is, I don't get to do a blowthrough in my truck due to my suspension.
I only have a regular cab, and since I put Honda Prelude seats in it, there is no room behind the seats, and there isn't much between the seats.
I didnt bother measuring length. I have a 5 speed so putting a larger sub upfront is out.
The width is about 8-9", should be perfect for some DD 6.5s with 1/2" board.
Has anybody used the DD 6.5 as a subwoofer in a limited space application? I may be able to run a few of these in an odd shaped box.SPECIFICATIONSeries: W6.5
Voice Coil Diameter: 1.5"
Magnet Weight: 28 oz
Power Handling RMS/Peak: 150/400
Suspension: 25mm
Nominal Impedance: 4.0 Ohm
DC Resistance: 3.1 Ohm
Model: W6.5
Rec Box (cubic ft): 0.5
Port Area (sq in): 8
Port Length (inches): 19
Woofer Diameter: 6.5"
Free Air Resonance: 36 Hz
Qts: 0.33
Qes: 0.34
Qms: 8.8
Vas: 21 L
Sensitivity: 91 dB
Shipping Weight: 11 lbs
