Distribution Block Question
JDfromtheIE
CarAudio.com Newbie
I am installing a couple of Kicker Key 200.4 amps along side my existing Kicker CXa1200.1 sub amp and I'm trying to figure out the cleanest way to distribute power.
I know I have to run a new 0ga power wire then distribute that to the 3 amps. The 2 Kicker Keys use 12ga and the CXa1200.1 uses a 4ga. I'd like to use this Fused Distribution block https://a.co/d/02Mga0N0
First question, will this work and also, how do I connect 12ga wires to 8ga outputs on the distribution block?
I am very new to all of this so feel free to tell me where I am wrong in planning this setup
It's great that you're venturing into setting up your car audio system! Let's break down your questions step by step.
### Power Distribution Setup
1. Power Wire: Using a new 0 AWG power wire is a solid choice, as it can carry the load for multiple amplifiers safely.
2. Fused Distribution Block: The distribution block you’re considering will work as long as it has the appropriate fuses for your application. The general approach for fusing is to use a fuse rating that corresponds to the maximum current draw of the amplifiers connected to it. Make sure that the total amperage rating of the fuses does not exceed what the 0 AWG wire can handle.
### Connecting Wires
1. 12 AWG to 8 AWG Connections: To connect 12 AWG wires to 8 AWG outputs, you can do the following:
- Use Spade or Ring Terminals: Crimp a spade or ring terminal on the end of your 12 AWG wire. Ensure it fits the screw or bolt size on the distribution block.
- Using a Reducer: If your distribution block has an 8 AWG connector, you can also use a wire reducer or a step-down Splice connector. This allows you to properly connect the 12 AWG wire to an 8 AWG input.
2. Fusing Recommendations: Choose individual fuses for each amp:
- The Kicker Key 200.4 amps typically draw around 20-30 amps depending on output levels.
- The Kicker CXa1200.1 sub amp would generally need a 100-120 amp fuse.
- Make sure the total fuse ratings do not exceed what the distribution block can handle.
### Cable Management & Grounding
  • Ground Wiring: Use the same gauge wire for your ground as you do for the power wire. It's essential to have a solid ground connection to prevent any noise or performance issues.
  • Routing Cables: Make sure to route your wires neatly to avoid any interference from other electrical components in the vehicle. Keeping power wires away from RCA cables will help reduce noise.
### Installation Tips
  • Check Amp Ratings: Confirm the power ratings of each amp to ensure everything is matched well.
  • Double Check Connections: Before powering up, double-check all connections to ensure everything is secure and well-insulated.
### Final Thoughts
This setup should work effectively for distributing power to your Kicker amps. Always remember to double-check your connections and ratings to stay safe and perform optimally!
Feel free to ask more questions or for any clarification, and I encourage other members to chime in with their experiences or tips!
That Block will work fine, used it many times.
Run 1/0 to the block.
Run a fused 4-gauge to the monoblock.
Use the 8-gauge reducers in the 4-gauge spots supplied with the block, and just plug the 12-gauge into them; it should work fine.
I think those little 4 ch Kickers will accept 10-gauge wire, might want to try these and just run 4 gauge all the way around if you already have it.
Otherwise, just run 10/12 gauge from the block to the two 4-ch amps.
Run a 1/0 gauge ground to a good ground within 18" (if at all possible) of the block.
This is good quality 10-gauge OFC wire, just what the doctor ordered if you're not going to use reducers.
That fuse block will work fine. You can twist the two power wires together. This will make them equivalent to a 14 gauge. I would cut the wires at about 6 inches from the amp then solder the 2 16-gauge wires to a 10 gauge and run it to the distribution block.
JDfromtheIE
CarAudio.com Newbie
JDfromtheIE
California
Old_Slapper
