Double Din Slot, 2 headunilts
then you can get a pocket and mount it below.
It's a 2000 Omega (new dash)
Hole in centre of the dash looks pretty much standard ISO, but has extra facia bits on the outside - so know I will need to do some glasswork.
Radio I took out was double DIN. Want to fit a headunit and in-dash changer...is there a kit for this for a std double din slot?
Cheers
i have a 1 1/2 din dash and put in a hu and a motorized dvd screen on top of that. It was TIGHT. I had to dremmel out a little at the top back of the hole that the hu and screen were going in but once I got the two parts in they were in so solid that it didn't need to be screwed in. sounds pretty ghetto but I cant get it to even wiggle.
Electronics can be very easy to troubleshoot. If it's getting power and ground and it still doesn't turn on, then the unit is bad. However...
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
3K
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
7
Look at the JVC brand. I have an older unit with a removable face plate. Model KW-AV61BT. Contact Crutchfield.com support for some current...
bubsnet
bubsnet
UK
plyhammer
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
