Double layered front baffle question
Depending on the size of your baffle, you might want to use at least 3 screws per side (each corner, as well as the middle). Using glue or liquid nails will seal it well, probably wouldn't hurt to throw 4 or more screws on there. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Electronics can be very easy to troubleshoot. If it's getting power and ground and it still doesn't turn on, then the unit is bad. However...
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
3K
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
7
Derek123
Derek123
Tampa Florida
EarDrummin.
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
