DVC or SVC subs
mrburner
okay i have a question, do you perfer DVC or SVC subs. The reason I am asking is because of wiring, for example:
I have an phoniex gold octane R. 800x1 @ 2ohm, 400x1 @ 4ohm
okay looked at the kicker comp 03CVR124 and CVR122:
2-ohm DVC models let you run at 1 or 4 ohms, while 4-ohm DVC models allow 2-ohm or 8-ohm operation.
know if I get a DVC 4 ohm sub does that mean my amp is only push 400 watts and not nowhere near 800 RMS?
Should I look for a sub that is at 2ohm so I can reach or get near my 800 RMS?
I'm alittle confused on this.
The final wired impedance is all that matters in how much the amp will put out. If you have a 4 ohm DVC and wire it to 2 ohms, your amp will "see" 2 ohms and put out whatever power it puts out at 2 ohms.
As far as preference, I prefer whatever will get me the impedance I need to match the number of woofers I want to the load my amp is capable of driving. If I want 1 sub and need a 2 ohm final load, then it doesn't matter to me if the sub is a DVC 4, a DVC 1, a SVC 2 or a QVC 2. If they made a triple coil 6 it would work.
okay, understand, but how do you wire a 2 4ohn subs to make the amp see a 2ohm load? or
2 2ohm subs to make the amp see a 2 ohm load,
I just to be able to wire the subs so that my amp will see 2 ohms
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
4
I would not recommend it if all subs are sharing the same chamber. I myself wouldnt do it at all. I would recommend get or having a tuned...
991
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
mrburner
mrburner
charlotte,nc
BoneStockSystem
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
