Eclipse EA3422 4 Channel Amplifier
This is the REAL Eclipse stuff and this amp has won many awards for best sound quality when it was released. If you look at the specifications you will see that it has extremely low THD, etc. unlike most of the amps that are made nowdays. I was using this amp to run my highs in my vehicle and I took a picture of it ON right before I removed it, so you can see its working. It is hard to find this amp in this condition!
Specs on the amp:
Max power Output : 123W x 4 ch (2 ohms)
Power Output (RMS Continuous Power) :
2 ohms - 70W RMS x 4 ch
4 ohms - 50W RMS x 4 ch
4 ohms Bridged 140W RMS x 2 ch
THD (Rated Power) :
@ 2 ohm stereo 0.008%
@ 4 ohm stereo 0.004%
@ 4 ohm bridged 0.008%
Signal to Noise (A-weighted 4 ohm) 105dB
Freq. Response @ 4ohm stereo 20Hz-20kHz +0,-0.7
Crosstalk 4ohm -70dB
Slew Rate 10V/us
Damping Factor @ 60Hz > 200
Input Sensitivity (preout) 0.2-5V
Input Sensitivity (Amp-out) 0.4-10V
Max Current Consumption (4ohm) 50A
Channelflex Crossover
High-Pass Freq Range - 12dB/octive 50~200Hz
Low-Pass Freq Range - 12dB/octive 90Hz (fixed)
Bass Boost (@45Hz) 0~9dB
Subsonic Freq. Range - 12dB/octive 20Hz
Dimensions (W x H x D) 10.82" x 1.97" x 10.82"
$70 INCLUDING PRIORITY MAIL SHIPPING WITH TRACKING.
I ship within 24 hours. Payment via Paypal only. Confirmed name and address only. Please PM me if you are interested or post in this thread if my mailbox is full. Thank you.
Specs on the amp:
THD (Rated Power) :
Slew Rate 10V/us
