ampjunkielikeme
275.00 shipped to the cont usa.... no trades..
do not be fooled by the name. this amp puts out some major power.
it shares a similar board as a Ground zero 3000.1, and Directed Viper 2500d, and Orion 2500d.. all of those amps are known to put out gobs of power. and this one will too.
ive read that it will put out a clean 2600 watts x1 @ 2ohm 14 volts.. not max wattage. RMS . im pretty sure a guy on here named dadon ran his at 1ohm with no problems. as long as you have the electrical to keep up. it should be fine..(i wouldn't do it. but thats me...lol)
cosmetics- i would give it a 8.5 out of a 10.. . it has a couple scuffs. but nothing major. it looks really good ...
it has all the speaker and power terminal screws intact... it is missing 2 screws that hold the little plexi top that covers the gain/crossover..etc. the 2 screws it has hold it down fine.. i may have some laying around to replace them. i will look..
functionality- it works 100% it has been fully tested.. it will pound just about any sub that is out there...
it would be perfect to run a huge single dual 1 ohm sub. (btl,nightshade,etc..)
that's what i would do with it...
specs:
Directed 2400d
1 x 1400W RMS @ 4 ohms at 12 volts
1 x 2400W RMS @ 2 ohms at 12 volts
dims: 24 L x 10 W x 3 H .. its a big ole amp... 2 feet long..
Same board as:
. Ground Zero GZPA 1.3000D
. Viper D2500.1
gut shot... it will have the bottom attached. i took it off to show the wonderfull board it has...lol its very clean inside..
The amp has been tested on my bench to operate normally. it will not to be DOA. No further warranty is expressed or implied..
specs:
Directed 2400d
Same board as:
. Viper D2500.1
![ppi884.jpg](/proxy.php?image=http%3A%2F%2Fi72.photobucket.com%2Falbums%2Fi195%2Fsparkys-crewcabdually%2Fppi884.jpg&hash=9e4e3642fe8033463cd47f752a800b21)
![ppi885.jpg](/proxy.php?image=http%3A%2F%2Fi72.photobucket.com%2Falbums%2Fi195%2Fsparkys-crewcabdually%2Fppi885.jpg&hash=36774e169f13211939faf51953f07fac)
![ppi886.jpg](/proxy.php?image=http%3A%2F%2Fi72.photobucket.com%2Falbums%2Fi195%2Fsparkys-crewcabdually%2Fppi886.jpg&hash=7c1c4dc89d2a5829f6758d7fd68b00f5)
![ppi883.jpg](/proxy.php?image=http%3A%2F%2Fi72.photobucket.com%2Falbums%2Fi195%2Fsparkys-crewcabdually%2Fppi883.jpg&hash=b9dbd69dfc746e329ec26faa64dfc5ed)
