brian84corvette
viechle 1990 chevy suburban. no provisions for door speakers from factory at all. none
also window motor it totaly in the way pressed basicly right up against the door all the way up in the front area - so cutting them in to the doors is most likely a terrible mistake.
external pods are needed.
pic shows pasanger side door stock - the lower carpet pannel is just attached with screws to the door remove - trace to wood - build pod to fit and test. then fleece and glass.
