focal and jl's 8w6's
  • 3
ovsims
nc
I'm thinking about getting some focal 4's or 5.25's to go with my JL 8w6's. Do you think the jl's will be able to make up for the loss in midbass since i'm not going with the 6.5's? Also i notice when looking for comps that MB Quarts said that none of their speakers (with the exception of subs) are recommended for any type of enclosure as it would take away from the overall performance of the speakers. I wanted to know if i would have this problem with the focal speakers as well b/c i want to fabricate an enclosre to house either 4's or 5.25's that didn't have a lot volume.
Depending on which line of Focal's you've got, they are known to handle a good amount of power so you could actually set your frequency response on the 5.25's a little lower to pick up a little midbass. I just don't know how the Discus series would hold up so be careful.
My bad, Discuss series are MB Quart, I meant the Access line of Focal.
How hi will i be able to set the jl 8w6's without damaging or making them not sound good. I can't find anything on their freq. response range
High frequencies won't damage them so that should not be a concern. What you do have to worry about is them dragging the imaging to wherever they are installed if you set the crossover frequency too high. They should play up to close to 200hz but above around 80hz you will be able to locate them.
yeah i know about it dragging the image but i plan on placing them in the front somehow. thanks for the freq. info that helped a lot. i think i'm going to get the Focal 100 KP's.
$2500usd package Shipping and PayPal fees extra I have a nice sub and 3way system available. All BNIB If you need more than one sub or rears...
Sound deadening and door preparations are key to getting the best results towards more SQ oriented within the vehicle, as well as speaker locations
I sure was eyeballing that Joker!! 👀 👀 :poop:! Nice amp!!
4
Excellent set of speakers if they're in good condition. I ran the home audio version of that midbass driver for a while. Still have them in my...
13
ovsims
ovsims
nc
ovsims
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
