Ford Exploder Wiring..
LEASNIT
Ok.. 2003 Ford Exploder... Factory 6 disc head unit, premium sound .... adding an amp using a low level adapter... any special wiring I have to because of the premium sound? .. And does anyone know the wire colors and polarity of them? ... Thanks.. ~ADAM~
Simply Space... it's a hybrid Maverick, so the battery is under the backseat on the passenger side. In order to utilize both of the 1000+W 5th...
178
Thank you!! Minus the backseat delete, that was the direction to go as it keeps the interior aesthetics. Could have gone off the wall in...
214
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
4K
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
LEASNIT
LEASNIT
Michigan
zerohertz
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
