Free-air vs. not
maylar
Electrical Weenie
3,566
31
Connecticut
My 2010 Cadillac DTS has a sub woofer hanging from the rear deck. Crutchfield says it's a 10" with non-standard mounting centers (why does AC Delco do dat?). Replacement suggestions are not all rated as free-air capable.
My understanding of a sedan's rear package tray mounting is that the very large volume of the trunk is pretty much infinite baffle, and would require a driver rated for free-air operation. Is this true? If not, what are the tradeoffs and why do they recommend conventional subs?
Pretty much any sub is capable of being run infinite baffle (free air). The trade off is lower power handling but you gain sensitivity and low end extension
Typically for IB, you want something with high QTS (.5-.7). You will lose power handling. You may need to make an adapter ring to fit an aftermarket sub to the OEM sub location.
I've heard the Dayton Audio UM series are pretty good IB. They just released the V2s after like a decade and half and I'm pretty sure the V1 s are on on sale.
If you want you can also pick up adapters from AK Audio to mount a 12 inch there. Comes in a pack of 2 1" spacers. 2 inches should give you the clearance to mount a 12. Will make the lows easier to achieve with the extra cone area. Could also go for SI SQL series. I believe in their site when ran in IB you can go down to 500 watts plus it has almost 2 inches pole to pole linear xmax
I'm doing my sql-15's ib (trunk baffle) in my delta
I bet they sound fantastic. I have mine in a small box ported to 35hz. Sounds great and gets super loud in my JP13 I just installed last night up from a JP8. Only downside is this ported box rolls off SHARP at 30hz. Pretty much nothing below that.
Probably one of the most versatile and best sounding subwoofers out there and only for $329
Manufactures in the budget to intermediary priced driver offerings (IMHO) tend to lean into the middle ground these days. The idea that any driver can be manufactured for IB, sealed or ported and be as good as one that is designed with one of those specific applications in kind is kind of silly. Don't get me wrong, some do it very good and you pay for it (Si for instances). What is the objective in your build?
My objective is a daily driver SQ system. I have a sub and amp from a previous install that I intend to reuse. It's a Boston G3 10" in a 0.5 cu. ft. sealed box that has awesome SQ and gets plenty loud enough for me. It'll go in the trunk behind the rear seat.
My inquiry here is in regard to the factory sub, and I'm considering options on how to deal with it. Remove it and let the G3 play through the opening, or put something really nice in there instead of the G3, or add a new sub with a couple hundred watt amp to supplement the 10. Just exploring options here.
Look at the Alpine Type S subs.
19
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
4
Why keep cramming your subs behind the seats when its inevitable that something like this is where you'll end up anyway. Most 12's with an EBP...
@robo191 Guess what? Happened to find exactly what you were looking for: link
maylar
Electrical Weenie
maylar
Connecticut
chillin
Joacimb
    Sep 3, 2024
Joacimb
    Sep 3, 2024
