Cascade Audio Engineering (CAE) APS-75 Power Supply
8/10 - Cosmetics. Some scratches to feet and housing (from normal use).
10/10 - Functionality
$165 shipped. Alaska, Hawaii, Canada will be more.
Although not a previous seller on here, I have excellent trader feedback on DIYMA. User "eg9" can verify.
NOTE: Needs a 20A outlet to plug into, if using household electricity. Like for a test bench.
Jumper is included. This boost voltage to 14.2V, for quick charging a battery.
- Super nice AC to DC, 75 AMP/1000 Watt (Continuous) Power Supply.
- Virtually silent operation; no low frequency transformer hum.
- Fan engages at around 75% of full load.
- Efficiency rating of 86-90%, with advanced switching design.
- May be used with or without a battery.
- Can be wired in parallel with another APS-75 for even more power.
- When not in use power is essentially off, saving electricity.
Only selling, because I have 2 of these and don't need all the power. Just use it on my test bench.
Very nice and clean for its age, and still rocking strong (mfg. in 2005).
Retail Cost: $372.00
Dimensions: 13" x 6.5" x 3.5" (13" includes the mounting feet)
Weight: ~ 8-9 lbs.
FAQ Sheet:
http://cascadeaudio.com/power_converters/pdf/aps_faq.pdf
Tech Sheet (Full Specs):
http://www.cascadeaudio.com/power_converters/pdf/APSSpecsOnly2006.pdf
Manual:
http://www.cascadeaudio.com/power_converters/pdf/APS_Manual.pdf
Weight: ~ 8-9 lbs.
FAQ Sheet:
Manual:
