SOLD FS: Xtant RGM - Remote Gain Module
  • 1
  • Locked
COMPLETED Xtant XIS 2.4
Also looking for the crossovers
You can connect the amplifier remote turn on to the red 12v accessory wire that turns on the stereo when you turn on the key. The amplifier will...
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
12
838
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
8
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
bikeboy24
bikeboy24
Toronto, ON
bikeboy24
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
