fuse question
so if i was going to do the alternator - battery in the "big three installation" i would need to get an ANL fusebox since it would be well over 100 amps?
yeah..I would. Those anl fuses are mounted with screws so you are sure to get a good connection. The agu fuses are held with pressure in clips so I dont think they get a good enough connection to move much more than 50 amps.
I was about to ask the same thing. Why would you want to wire the batteries in series. But then you said you were connecting them to the same...
5
287
At full power, you will be drawing about 450 amps. However, I doubt you will be pushing your system that hard. So, that being said, I would use...
491
substance
substance
houston
homer3304
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
