fuses and stuff
ckarls2000
I need help finding fuses and battery terminal hookups.
I am running a BX1500d to 2 212l7s at 1 ohm.
I have 4ga wire.
I need to find somewhere to get a fuse block for this.
And i also need the things that go on the positive and negative battery terminals at a good. deal anybody know of any places online to get these?
check out http://www.darvex.com Most likely they will have what you need. What kind of battery do you have? Is it side mount post(GM) or top. If it is just a top mount post then a ring battery terminal will work because you will be connecting one amp. You won't need a dist block because the amp has 2x60 amp fuses already on it. Just a straight run from the battery to the amp. You will need an inline fuse as close to the battery as possible(less than 18 inches). Pretty straight forward. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Should be good to go without those fuses. Read the manual that comes with the new stereo. If it doesn’t say to add additional fuses, don’t.
Absolutely not!!! Acetone eats everything it touches other than metal that is.. there is a reason it comes in metal containers with metal caps...
11
use the icon where it says insert image, icon. press that. How to get your pictures on your computer? Use your iPhone. Then transfer it to...
What would be your cost savings per unit having your coils wound in aluminum instead of copper? Can you quantify the efficiency (or dB) gains...
5
ckarls2000
ckarls2000
Everett, WA
bass_head
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
