Gains: as is or re-tune
sciontistbb
So I’m thinking of changing subs. I currently have an SA12D4 on a BRZ1200.1D
I tuned this with dmm at a target voltage of 42.42 for 900 watts @ 2 ohms. Found a great deal on a SA D2 and planning on running it a 1 ohm. With this said, I will be running 1200 watts @ 1 ohm. Do I leave my gains the same or to I need to change it? If I do tune it again my target voltage is going to be 34.64. (1200 x 1 ohm)
Can some one explain why the gain will be set lower to create 1200 watts?
900 watts x 2 ohm sq rt is 42.42
1200 watts x 1 ohm sq rt is 34.64
Will I need to change box design? I currently have just a little over 2 ft^3 after displacement tuned @ 32hz
What I'm guessing is your amp isn't making 900 at 2 so you are driving it into clipping to get that voltage.
There is no clipping or at least I don't think there is. I should have mentioned that I had a local shop use an SMD DD1 a few months ago and passed the distortion test. I have yet to fine a shop within a reasonable distance with an o-scope.
When I tune myself with the DMM method on 40hz I backed off my target volt of 42.42 and left it at 40.ish
you can leave your gain as-is. the gain (input sensitivity) is matched to the head unit, not the sub. you can adjust sub output level with remote bass knobs or sub level control on the head unit.
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
That's nothing but an annoyingly common phrase to try to sound smart. Don't say "gain is not a volume knob" until you can explain how it differs...
10
sciontistbb
sciontistbb
In the garage
keep_hope_alive
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
