ive been installing a jvc hu in my boat (2001 CHAPARRAL). i replaced a 2 speaker seacraft (or something like that) with 2 infinity refrence 6x9's and two refrence 6.5 in the stock locations. i rewired the new hu to the old harness but it will not turn on. (it has ounce when i hooked the battery back up but turned off half a sec later). the ground and power wire are very small could it be there not supplying enough power to turn it on? i could wire the 12 volt wire to the battery right? were could i ground it to though?
i believe i wired evrything right but im not sure about the yellow (12 volt) wire. i hooked to the same wire were the old h/u claims "fuse box" (there is no slot marked 12 volt). that wire connects to a small fuse box. do u think i could have blown the fuse? (i was so pissed leaving i didnt check) if so should i get a bigger fuse? what size?
i know i have aot of questions but plz help me out
thanks,
ricky
thanks,
ricky
