Head Unit/Radio Shuts Off While Driving?
echachanny
I have a 99 Chevy Blazer. I just bought the car 2 days ago. There was already an aftermarket Kenwood head unit in the car which ran perfect and did not shut off. I had a Sony head unit which is brand new and installed it myself because it looked much nicer with more options etc. I have done plenty of install but never had a problem like this. I turn the key to accessory and the head unit comes on and plays perfect. Start the car and it will come on as well but the moment i rev the engine a bit or put my car into gear it shuts off completely. It will flash on and off constantly while i'm driving which is very annoying. The only time it sometimes will come back on is at a complete stop, but once moving again, it shuts off. When I start driving it will usually flicker on off on off and then completely shut off as though it lost power. I have checked all my wiring which i did using the crimp things and its all good. I cannot figure this one out guys and i really need help. Also advanced auto ran a scan on my battery and said my battery had a low charge but i don't know if this is what causing the problem completely. Any advice?
I had something very similar happen when a cheap in-line fuse holder cracked. The holder broke and the spring couldn't press the fuse against the contacts. Check in-line fuses in the harness carefully.
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
Plenty of options to choose from and as stated above comment. Kenwood/JVC are great options, and Alpine as well within most peoples price range/...
87
Look into idoing hear units, I know lots of people use them in the 15+ WRX's, I myself used a maestro unit and head unit capable of using it
131
If you can tap before the Bose amp, then you may only need a simple LOC. If you tap after the Bose amp, then you will need a bass restorer/LOC...
So I went to another Audio specialist. He unplugged the radio and sent me first to an electronics specialist who can actually open up the radio...
26
749
echachanny
echachanny
Chesapeake, VA
Jepalan
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
