Help Amp Doesnt exist!
lcpunk69
SQ Baby!
I swear ihave looked forever its impossible, im looking for an amp that will do around 1100-1500W @ 12.x V rating X 1 @ 2 ohm, and it needs a SSF and good protection features. Why doesnt a amp like this exist!!!! //content.invisioncic.com/y282845/emoticons/pissed.gif.9f665f96bc89e98e708dabd4580bb591.gif//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
How about Rockford fosgate bd1001 or 1501's?? I believe they put out power at 2 ohms, but I'm not sure if it is 12 volts, probably 14.4. If you got the 1501 i'm sure you would get 1000+ at 12 volts though.
Craig G
PG does 1400-1600 @ 2ohm...say a few birth sheets at local shop. I THINK it was @ 14.4 but not sure...anyways would still fall w/ in ur needed power...round 1100-1300 2 12.x V, peace
NG
simple, they don't make amps like that anymore... but you can find an Orion HCCA 225 off of ebay (they are red) the best cheater amp ever made, they handle that wattage stable at 1 ohm
my fault didn't see the @12V, dang.. you asking for 2 much.. buy a 2.0 / 2.5 digital cap, it will push the voltage up...
the VR2000 is hot, used in alot of comp's.. hell just by a USA amp under rated, expensive as hell and they will give you what you want.
lol, 14.4 when the car is running with a high end system... someone doesn't have a volt reader...
i bet you're closer to 12.5 buddy.
y u need 12v?? thas wit car off, wen its running its like 13-14.4 volts......
that's why people upgrade to high output alts. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I talk about these boxes a lot, maybe cause Im biased, but they are just great boxes...
12
834
I had this same amp installed about 9 months ago with no issues whatsoever which make all this odd
10
11
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
lcpunk69
SQ Baby!
lcpunk69
Gainesville, FL
paikiah
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
