Help choosing budget subz
  • 4
Gioss
I know there is another thread with the 2 for one special on Crutchfield. But this is what I want to do. I have an extended cab silverado and will be getting the box that fits under the back seat. I can either put 2 10s or 2 12s. I already have an older Rockford P2 10 inch, the older silver one. another woud be 79.
Should I do:
RF P2 10s
Apline SWE 10s
MTX t5510-04s
or
Polk MOMO 12s
I have a soundstream 1000s that I am going to run one channel at 2ohms since one channel is blown. Got it fixed and blew again, so just going to use the one channel for now.
I am leaning towards either the momos or the 5500's
thoughts? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
so none of these subz will do the trick? I am just adding bass to the bose system. I already have a car with a full set up. Impala SS 96 with MB Quarts, Type R 12s, and PPI amps. This is for my everyday truck that I park on the street in NYC. So $$ should be cheap in case they break in.
out of the list above, which would be better for a small enclosure and 400 watts?(which is what the soundsteam with put out at 2ohms in one channel)
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
11K
Not at all, amplifiers have gain control to attenuate the output to safe levels.
6
Gioss
Gioss
Queens, NY
Gioss
ttt123
    Jul 2, 2024
ttt123
    Jul 2, 2024
