help dis man please
projectpatza
just bought a brand new duralast battery with 650 cold cranking amps and a lighting auto 1 frad power cap ihave a two orion 10 inch h2 on a 700 watt 4 channel kicker comp amp on a 1 frad power cap in a ported box should that be enough to keep the strain of my factory altenator with replaced barrions in my 1993 nissan altima gxe my alt puts out 80 amp. should i run a ground wire from the power caps negative back to the battery negative. people tell me im not taking alot of power because my amps only 700 watts and i have more then enough with a 1 frad power cap because a 1 frad cap is for 1 thousand watt amps so i should be good right
I like the Pioneer. I have personally used Pioneer, Kenwood EXcelon, Alpine, and JVC. I liked the Pioneer the most. The Alpine is next, but is...
7
370
Tryna figure out what's the best speaker option for my car I have a space for a 4inch speaker and with some trimming 8 inch hole in the door not...
Damn straight. I had one in a 1 cube ported to 35 Hz iirc. It was not that deep but played everything I liked with authority. They were Kove's...
8
537
projectpatza
projectpatza
rochester NY
zerohertz
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
