Piggnford
Installing a Clarion NX 404 in my 2003 Yukon SLT with Bose, XM and onstar. Got the radio installed using the PAC C2R GM24 interface. It doesn't appear this interface supports Onstar, which I didn't think mattered. The FM radio works great, along with the navigation.
The problem I'm having is I can only get sound on FM. I can easily connect to Bluetooth and it shows its playing. Just no sound. None with front 3.5 mm aux plug either. Volume is up on phone and unit. Is it possible using the wrong interface is causing this issue? If so, what interface would you recommend for my setup? Thanks so much!!
