help: subs, same chamber
simon21
NY
Hello everybody. I have a box with two 10s in the same chamber and one of them isn't like it used to be. It got depressed during storage and now doesn't make as much bass as the other one. What should I do? Should I cut the box in half and make two boxes or should I buy new boxes to put them in? How would I cut the box in half? I don't want to spend a lot of money. Should I just keep it the way it is and be happy? Any suggestions or ideas?
Thanks
why not just seal an area between the subs? i don't think your supposed to have 2 subs sharing the same volume in a sealed enclosure int he 1st place.
You can connect subs with wires in different ways and that can change the ohms (resistance) the amplifier sees. Too low of a load (closer to 0)...
380
Probably won't hear now till Monday but during the week they respond in a decent time. Also send a msg via facebook if you haven't as I usually...
6
You could do the 8" as a front sub on its own amp and use it to bridge/enhance the gap between your 12" in the rear to the midranges
6
simon21
simon21
NY
Logikalliquid
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
