help with my box please
riddla
nf
yo dudes, wats up,
my box dimensions are 34 Long x 16.5 W x 16 D...
I built this box off my head a long time ago & wana use it for 2 x 12in vibe subs rated at 350w rms & 700w peak power.
on the specs tho, it said use a box of 1.5cubic ft but what i wana know is how much would this box size be..
its got split chambers & i wana port it as well for the sub in each chamber..
fs in hz in 32
QTS=0.51
VAS in cubic ft=3.34
VAS in litres=84.50
Xmax in inches=0.29
Xmax in mm=7.5
max power in watts=700
QMS=4.86
Zmax=34.15
Fo in hz=32
magnet weight=50
recommended sealed enclosure = 1.5 cubic feet
This is the spec of the subwoofer & its calle vibe pt120 series..
Ive seen loads of these boxes ported from the manufacturer but i would like to know if the box ive made is suitable & how big & long sholud i make the port?
Any help would be graceful as this is doing my head in
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
6K
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
5K
riddla
riddla
nf
riddla
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
