Hifonics BX1000D
Yeah I saw that when I got mine. I was like wtf? Its 1000 at 1ohm.....I think. I haven't had it tested but it push's my 2 12 cm3 d4 very well.
supposedly what people that have tested them are sayin is that if your gettin the new brutus series, run them at 1ohm or get different amp. if you run them at 1 ohm you get the full 1000 or 1500 depending on what amp you get but if you go with a 2 ohm setup then you get a lot less watts. this is not from experience, this is from what i have seen from other people that have used them
You should be fine, if they are set up at 1ohm. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
blownsix
blownsix
Bham
FinalWolf
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
