honda accord power sterring pump
  • 1
fatboyracing
Owensboro KY
seeing if anyone knows an awnser
I have a 2005 accord v6 in the mornings worse the cloder it gets I have a grinding noise when I turn the wheels stoped or rolling sounds like it is comeing out of the power sterrin unit.I am going to try to change the fluid this weeked any other suggestions?
oh by the way the noise goes away after the car gets warm. the pump has no leaks.
I don't think OP is going to do the deadener themself, but these are my tools for it. If its 80 degrees out, you can just leave it out and it's...
7
4K
When I first started with upgrades, I purchased a harness that allowed me to add an amplifier by tapping into the factory wiring. It was a PAC...
7
3K
I thought you had two amps?? What happened to the wood that you were going to have H.depot cut out?? Looks different to me for some reason. Do you...
9
3K
This is the max fuse sizes for the knu wire. The kca 4awg kit can supply 100amp to the rp1200.1 but it won't have enough left over for the rp75.4...
26
3K
fatboyracing
fatboyracing
Owensboro KY
fatboyracing
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
