I need help with Apline Head unit
tasmisr
MI
Hi everyone,,
this is a very newbie question, I have an Alpine CD Player (3 cd in-dash changer).
I want to take the head unit out in order to change a guage..I tried to take this thing out by knifes and pry tools but it's doesn't come out.. How do u guys do that? is there some tools I should buy?
The model number is 3DE-7886S
thanks.
YES THERE IS. Go to a dealer in your area that sells alpine and see if he will let you barrow the removal tool for a few min. Take it out and there you go. DO NOT PRY on it or you will break it. If you bought the radio new you should have gotten the tool in the box. If you bought it and they installed it they did not give you your tools back.
Sorry. If they installed the HU they may have put the support strap on in the back of the HU. if they did, you may have to take your whole dash out to get it off.
Is there a list fo Alpine dealrs by zip code or something?
I bought the car with that thing installed. It's just frustrating...
yes there should be on the net or Im sure that a local shop more than likely carries alpine..just give a couple of the shops a call...and ask...should be no problem at all...unless they did place a starp on...
Damn straight. I had one in a 1 cube ported to 35 Hz iirc. It was not that deep but played everything I liked with authority. They were Kove's...
8
537
Killamat and Siless is the same thing. You don't need the thickest stuff either. You're not competing in any DB drags. The 50 mil will be just...
498
At full power, you will be drawing about 450 amps. However, I doubt you will be pushing your system that hard. So, that being said, I would use...
491
WANTED Need Help
I definitely always wanted a set ....dual had a set also the XF series I believe ...it had the red aluminum cone with big surrounds ...I've ran...
794
tasmisr
tasmisr
MI
12vlt4life
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
