Ideas to try?
  • 2
firefighter1225
I have a 2008 Charger with the following gear.
1. Tweeters in the a-pillar with 4" mids in the dash using a passive x-over, the low side x-over is set at 200hz/24db.
2. 8" midbass in the doors x-over set at 65hz/24db-200hz/12db.
3. 2-12" subs in the trunk firing forward thru the seats in a sealed wall x-over set at 65hz/24db.
It sounds good but it sounds better (thicker, a fuller sound) the closer I lean towards the dash, I going to do some tuning this weekend, but before I start I was looking for some ideas to start with to save time. Should I try changing the phase of the subs or maybe the midbass? Thanks for any suggestions!
it sounds like that bc of the pressure coming off of ur windsheild. . their bouncing off it and back at you so ur getting waves from the dash and behind u from the subs.
and what r u trying to do? make it louder or just tweak the settings to make it sound better?
Here's another one I was looking at
They use them in dueling demo classes. But those aren't just the horrific sounding pro audio type.
9
Thanks Shedder, I had though about 4th when I first started thinking about everything, even before I ordered the subs. Really still in the very...
4
975
firefighter1225
firefighter1225
Minnesota
firefighter1225
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
