im confused
diminishedpower
I Like Chicken
938
Iowa
i have 2 kicker xpl's rated at 8 ohm svc. rigth now im runing each one on its own channel on a 2 channel amp at 300 watts, i wanted to kno what would be my best bet for my next amp and what should be the set up on it,(the subs are rated at 500 watts max)
What's The Rms Of The Subs..
Add The 2 Numbers Together And U'll Want An Amp That Puts Out That Amount Of Watts @ 4ohms
Question, are you saying that your current amp is putting out 300w a channel into each channel at 8ohms or are you saying that your amp is 300w total to both channels. If it's 300w total try bridging your amp and running your 8ohm subs wiried into a single 4ohm mono load. I'm sure you will notice a HUGE difference with the equipment you have.... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
It looks like you have the wrong connections. The head unit uses one amplifier to amplify 2 to 4 of your speakers. You are using 2 amplifiers...
5
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
Dayuuum!! LOL. Going CHEAP sometimes doesnt pay..LOL 💩 💩
13
Hey guys I'm new here I'd like first and foremost that I'm not greenhorn but I haven't been an installer for 10+ years either. So the issue I am...
diminishedpower
I Like Chicken
diminishedpower
Iowa
DARKHART
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
