Imaging X-over Question
nosaj070
Chicago, IL
I have my type x components with the tweet in the door panel next to the handle, and the mid in the stock location. Now my question is, why is it recomended to cross the tweets so high, like 6-8khz. I lose lots of stereo response because I can hear the right side much better because my legs aren't blocking it. The tweets really only play symbols and add a little definition to the vocals. Now i would just go and set it lower, but I have heard that technically that is the best settings for ultimate imaging. Thanks.
-Jason
It's a guidline, but not a rule. Generally speaking, crossing over the tweets below 4-5kHz, you sometimes run into separation issues Between the mid and the tweet.
Not to mention, several mid's can play into the 1kHz and above range. Taking the tweeters down to a lower frequency may also cause them to be greatly over-bearing and painful in some cases.
It largely depends on the response of your midwoofer, and it's frequency limitations.
Component position also has a lot to do with this issue.
CDT and Image Dynamics make coaxial comp sets too. If you DSP, point source looses it's advantage over being able to move the tweeter around to...
16
I know, generally speaking, that doing what you’re doing will give you some semblance of what the end result “should” be. That said, driver types...
7
Thanks. That was my ending thought as well but didn’t think of it! Thats why I’m just an ole boy and not a programmer! Thanks for the reply...
316
Use any negative terminal or positive terminal slot out of the amplifier outputs or speaker outputs. Only one positive and one negative should be...
649
I talk about these boxes a lot, maybe cause Im biased, but they are just great boxes...
12
834
nosaj070
nosaj070
Chicago, IL
zane
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
