jkafkazo
hi,
I have a head unit....it is grounded to a screw in the chasis....powered to the harness....rca cables run from it to the mono amp input.....then from the mono amp output rca cables run to my 4 channel amp.....both amps are grounded well....i have a 4 gage power cable running from my battery to a distributer block....then from there two 8 gage power cables to my amps....rca cables are on the other side of the car then the power cable......
NOW MY PROBLEM
i hear a noise in my speakers....its a noise that when you press the gas pedal it goes higher....i read about it in the forum...alot of people seem to have this problem......what is my problem and what can i do about it....i tried everything....like..grounding straight to the battery or grounding everything together...or getting a ground isolator loop....nothing takes it off....
plus, if i play something laud i guess i can deal with it cuz you cant hear it that much but it still ***** ass......now one thing i did is set the volume on my amp low and it took it all away but it was too low...like 30%.....i would rather fix the problem another way.....coult it be an alternator? battery? ....it is an old 1990 jeep wrangler.......PLEASE HELP.... any suggestions will be well appreciated.....THANKS IN ADVANCE!!
NOW MY PROBLEM
