Interior dismantle for sound deadening project
48Blocc
Hey all, I'm looking to sound deaden my 96 grand cherokee limited from top to bottom. I've already got a good start with a layer of brown bread on the doors and hatch, but I want to get a couple layers down on the floor. I was wondering if any of you had any good ideas about how to approach this. Should go the whole nine and take out seats, consoles, etc? How far should I go? Can I get away with just pulling up the carpet around the seats and laying down some layers there? Anything I should be careful about (esp concerning taking out seats and other rather essential equipment)? All help and suggestions are greatly appreciated. Thanks!!
If you must deaden the floor which probly already has carpet and insulation. then just getting around where you can will probly be fine but i dont think youll notice a difference whether you deaden the floor or not IMO
there's no easy way. The effort you put in will have a direct affect on performance of the damper. You should really concentrate on the firewall, the center (where the exhaust pipe and transmission will run), and the spare tire cavity.
Sice it's the floor, i also suggest using a layer of udnercoating (bedliner) to makeit even more effective, it's what I did.
To fix your cracked dash, I would recommend the JB Weld Plastic Weld putty. I've used it a few times on plastic parts, and it worked pretty good.
9
392
Thanks again to all who replied here! New speakers are in, sound good and I can finally hear the XM preview instructions on the OEM GM radio. I...
14
258
Simply Space... it's a hybrid Maverick, so the battery is under the backseat on the passenger side. In order to utilize both of the 1000+W 5th...
178
Ahh fahh, forget my first answer. You were absolutely correct on the outputs being switched! Thanks a lot for your help. Really appreciated!!!
240
48Blocc
48Blocc
Santa Clara, CA
paikiah
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
