jbl 1200.1
so if I have 2 dvc 2 ohm subs and wire them down to a total of 1 ohm then wire it in how many watts am i getting? so i should wire the subs to one ohm each and wire them both up?
it puts out 1200wrms+ at 1 and 2 ohm
like this, wire them so the amp see 2ohms
i dont think ur understanding what an ohm is. an ohm is resistance. u wire the subs up to a certain amount of ohms. an ohm load. which the amp will handle.
so u have 2 dvc 2ohm subs. they can be wired together for a 2 ohm load. at 2 ohms, the JBL 1200 will put out 1200+ watts
its a 1 channel amp. it has two terminals, but they are still the same channel. If you plug each sub into one terminal, and each sub is wired for 4 ohms, you will be giving the amp a 2 ohm load and get your 1200wrms.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
  • Locked
COMPLETED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
8K
Burnboy
Burnboy
Kentucky
Bavarian3
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
