Jbl gto14001
The JBL 14001 will defintely put out what it is rated to do. I own this amp myself. Although it will do rated power at 2 ohms it is however a power hog. The efficiancy of this amplifier could be alot better but then again if this is the only amp that you are running then it will not hurt much.
I do reccomend this amplifier if you are running a basic beginner system but not to power a true spl vehicle.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
7K
MurderCobalt
MurderCobalt
bobbyh3342
Hobib Ali
    Jun 24, 2024
ThxOne
    Jun 22, 2024
